Nokia 5130 Cellular Phone Logo
Posted on Oct 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im in san diego usa and my nokia 5310 b I bought on craigs list is asking for a "security code" ive tried all the default codes "000,12345,, and even the master reset code. Nothing is working. Also any time the "#" key is pressed it goes straight to "code error" like when entering other codes. Help please...
Anonymous
Level 3:
President:
  • Nokia Master 1,932 Answers
  • Posted on Oct 07, 2010
Anonymous
Nokia Master
Level 3:
President:
Answers
1932
Questions
0
Helped
519181
Points
6158
Hi
The default Security code is 12345.
If you changed it and forgot the security code please contacts your device dealer. They will provide you the default security code so that you can use your phone.
This security lock prevents thieves from being able to make use of stolen handsets that is why it can only be unlocked by authorized device dealers.
Thank You
Anonymous
Level 3:
President:
  • Master 2,777 Answers
Anonymous
Master
Level 3:
President:
Answers
2777
Questions
0
Helped
665935
Points
9584
Either the phone is defective or it really does have a security code in place. Have you contacted the person you purchased it from? Without that code the phone is unfortunately useless.
Thanks
Tim
  • Anonymous Oct 08, 2010
    It may be talking about a subsidy code too. If it's a GSM phone and you are running a SIM card that is designed for a different network than the phone was made for, this may be the issue and in this case there is often little or no recourse aside from getting your money back.
    However, to reset a security code, the master reset code is *#7470#
    If that still don't work try pressing * (call) (power) at the same time.
  • Anonymous Oct 11, 2010
    Please if possible come back to the question here and rate it 4 thumbs. It looks like the answer helped you, but for some reason it doesn't rate it 4 thumbs unless you come back a second time and specify 4 out of 4 thumbs. I hope you will do this for me.
    Thanks
    Tim
I canot open my cell phone ,it saying me to aply the sequrity cod
Th phone asks for the security code you have set in your mobile.Default security code is 12345.If you changed default code use the changed security code.If you forgotten security code try using master security code which can be obtained from sites by providing imei number link http://www.unlockme.co.uk/master.php
What's the default security code of nokia 5310?
The default security code of Nokia 5310 is 12345 .
For Nokia phones almost default security code is 12345
1helpful
Unlock security code for nokia 5310?
Hi there.
The default security code for the majority of Nokia's is 12345. The code can also sometimes be 0000 or 000000.
If it is the security code, then you can try unlimited number of times without the phone becoming locked.
Hope this helps.
3helpful
I forgot my Security code for Nokia 5310 Xpress Music
Instead of Security code, try lock code. It works for a large no. of phones. If it is not working, take it to NSC, they will update the data to defaults, the security code will also become default. You can get the default in the manual. Thank you, Have a nice day.
2helpful
2answers
How to unlock security keyguard on nokia 5310 ???
Go to 4shared and download "reset nokia security code" software. Put your IMEI number in it. It will generate the master code for your mobile. Do not keep your sim card in your set while entering it. Before even trying it, just remove your simcard from your handset and try the default pincode. Mine is nokia 3110c it has code 12345.
Thanks
2answers
Nokia 5310 restriction code
Hello there, your IMEI no. is 359813010646423 and the code master code is this, 5146730640.
When you enter the master code, the current security code of your phone will be override, so i suggest that return the master code to default which means 1234, and then you cab change that lately.
Hope I help... :D
1helpful
Restriction code for my nokia 5310.
To Unlock your phone
  • Insert sim
  • Turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code.
  • Press C,then press * message should flash
  • Press * again and 04*pin*pin*pin# \
    *#7328748263373738# resets security code.
  • Default security code is 12345
DO Rate Me
8helpful
5answers
Nokia 5310 security code unlock
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
