As soon as pc starts up it shows the top of post screen and then goes into automatic recovery and asks for bios disk,tried downloading from packard bell and gigabyte but when i insert floppy it says no bios found,it wont let me get into bios with f2 or f1 so i assume there is no bios on pc,it just wont let me do anything,please help
SOURCE: BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
SOURCE: Technician
just go on giga byte get manel for it all latest drivers what issues are u having im open for chat thx nick
SOURCE: Packard Bell IMedia 5055: GA-8SIML will not post
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
if there is no bios on your pc,then you should not be able to see the post screen...because the bios did the post test
check for the bios jumper..clear cmos..load for optimal seting or failsafe setting first
