Question about Nortel Lands Phones
Nortek T7100 crackling coming out of the speakers when handset is down.
    President:
  • Nortel Master
  • 860 Answers
It could be that the background music feature is turned on but doesn't have a misic player attached. Try entering in feature #86 while the handset is in its cradle.
Posted on Oct 08, 2010
6ya staff
SOURCE:
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
Crackling noise on yealink t46g
first check if the problem is only on the handset, or if it happens on the speakerphone as well. if the problem exists on speakerphone then (as long as you are sure the issue is not with the SIP service provider, or with the other end of the conversation) the entire unit needs to be replaced... if the problem disappeared when put on speaker phone, then the issue is with the handset, or the handset cord. replace the handset cord and test again, if the issue remains then the handset needs replacing
Jul 28, 2014 | Yealink SIP-T46G IP Phone - POE
How do i delete a 'Message for You' on a BT T7100?
Lift the handset then press #65 then press HOLD button it will delete the "Message For You".... just send a "thank you" message to my email....nzdatangel@yahoo.com
Jun 03, 2011 | Nortel Networks T7100 Corded Phone
BT T7100 is saying 'Message for you' and cannot work out how to access it of how to get rid of it!
Lift the handset then press Feature button then press #65 then press HOLD button it will delete the "Message For You".... just send a "thank you" message to my email....nzdatangel@yahoo.com
Feb 23, 2011 | Nortel Networks T7100 Corded Phone
Lost my disc to instal nortek cam
Any hardware connected to PC, needs proper drivers to be installed, in order to use it. So each such hardware comes with the driver disk for different versions of OS. Please check what's related to yours.
Jan 21, 2010 | Computers & Internet
Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Aug 26, 2009 | Dell WL6000 Computer Speakers
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Speakers are crackling
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Jan 17, 2009 | Car Audio & Video
Lands Phones Logo
128 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
