Question about Acer (91.16848.010) Video Capture
No Acer video capture device was detected on your system.
  • jvanstrate Oct 07, 2010
    no disc came with my computer brand new out of the box...
    Any other suggestions?
    I can access the Acer cam for my performer application. Problem is, I can NOT take photo's using my performer application. It only allows me to broadcast live video.
  • 590 Answers
You have to use the driver cd which came along with your device and install them and this will install the driver for your capture device and your hardware will be detected.
thanks
Posted on Oct 07, 2010
SOURCE:
My acer aspire 5734Z-4360 crystal eye has stopped working. It indicates no Acer video capture device was detected on your system.
Update the webcam driver in your computer. You can get the crystal eye driver from the website of acer. But if you would like to cover all drivers in your computer then you can use RadarSync scan so that you will know which drivers are outdated. Keeping them updated would fix the issues.
David
Jun 07, 2013 | Computers & Internet
No acer capture device found on your system
Your driver has been disabled. To re-enable it (in WinXP)
START > Control Panel > System > Hardware (tab) > Device Manager (button)
Find your device - Right-Click on it > Left-Click on the Enable (button),
or after Right-click - instead of "Enable" you can select "Troubleshoot"
If you're running WinVista or Win7, these WinXP instructions may (or may not) be close to what
you need...
Feb 13, 2011 | Acer (91.16848.010) Video Capture
When i use to open my acer built in web cam ........ it shows an error.......... that is "no video captured device was detected on your system"
Go to control panel, double click system , click hardware tab and click device manager. Check there if you can see your Genius Look 315FS Web Cam is installed. If none or there is a device with a question mark. That means not yet been installed. Or try to switch your webcam to the other usb port if your computer detect just click next and so forth and if asking for the driver install it and test. Good day. Always remember for the compatibility hardware. It must be compatible according to operating system. Good Day.
Nov 30, 2010 | Genius Look 315FS Web Cam
No video capture device was detected on your
Copy this site and paste it in your browser ADDRESS
Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully functional video capture application compatible with Microsoft
DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard
and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features.
program.
AMCap is a small and effective piece of software and definitely worth trying.
Hope this will help. Bud
Mar 13, 2010 | Genius Look 315FS Web Cam
HOW DO I USE MY WEBCAM ON MY ACER ASPIRE ONE NETBOOK?
Certain models have are shipped with Acer Crystal Eye Webcam software which enables webcam at boot. I do nto know if it is installed in your netbook.
To test the webcam running Windows XP, follow the steps below:
  1. Go to Start, All Programs, then Windows Movie Maker.
  2. On the left side, click the link for Capture from video device.
  3. Select Next throughout the set up, making any file name changes or setting changes if desired.
  4. On the Capture Video screen, click on the Start Capture button
  5. You will see the video on the right with a time count up
  6. When you are done click the Finish button
  7. Click the play button on the video clip, or drag the clip to the Storyboard below.
If your webcam is not detected or if you are running Windows Vista click the link below.
The wesite has live chat support in case you get stuck
http://netbooks-us.custhelp.com/app/answers/detail/a_id/86/related/1/kw/webcam/r_id/166
Jan 13, 2010 | Acer Aspire One AOD150-1920 Netbook
Camera not detected on firewire port
it will only be detected in a Video Capturing Software , select ur camera options menu and check for the output mode needs to be DV studio or somethn glike that
and then go to the capturing software ur camera will be detected as DV device when in capturing mode turn on the camera and select device from teh drop down list
which capturing software u are using kindly ask me for exact info on that
Nero
Ulead
Cyberlink or what
kindly rate me WELL !
May 17, 2009 | Intel Computers & Internet
To capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
Feb 07, 2009 | Acer Aspire 6920 Notebook PC
I cant find the webcam icon
Use ACER Arcade application.
From User manual:
"Acer Arcade allows you to capture and record video clips from other external
devices, such as a DVD player or camcorder.
Click Capture Device on the video page and then select the source you are using
for your video input. There is a choice between "S-video" and "Composite."
To capture a video clip, you then need to click the red record button in the
onscreen controls.
The destination folder can be set from the "Settings" menu.
Clicking on Advanced and selecting Settings allows you to set the quality of the
video captured. You can choose from "Good," "Better" or "Best." Selecting a
higher quality results in a larger file when capturing video clips.
Snapshot
Snapshot mode is available in Cinema, Video and TV modes. This function can
be used to capture the onscreen image at any time."
Jan 05, 2009 | Acer Aspire 5610-4648 Notebook
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Televison & Video Logo
5,635 people viewed this question
Top Acer Televison & Video Experts
Eric Rotmil
Eric Rotmil
Siul Oyaratgam
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
