When i power on my pc the monitor display "Not optimum mode: Recommended mode 128081024 60 Hz" when i presh Menu button it's display "Test is ok" Please help me
Same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
I have the same monitor with same probelm. I dont know if this is problem with samsungs specific model but the only way to work is the follow.
1. connect your pc to another monitor and set the resolution to 1024x768.
2. set the herz to 60mhz.
3. save the settings .
4. connect your samsung monitor with your pc
You must get clear picture. I dont know why it works 1024x768 with 60hz and not at higher resolutions but this is the only way to work the samsung syncmaster 713bm
Same Here But Is A Faulty circuit board
same exact problem!
I have the same problem but I have dual monitors and only one is doing it other one is perfectly fine. Any solutions?
I have the same problem. I hate Samsung
