Cars & Trucks Logo
Posted on Oct 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The suspension fault,normal height only pops up on the screen some times.what could this problem be please help with an answer. thank you
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on Oct 07, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
73309
Points
195
Need to get the vehicle scanned for fault codes.
The most common issue is the air pump/compressor for the electronic air suspension.
Relatively easy to replace, but you still need to get the vehicle scanned for fault codes. Once the fault has been repaired, again you will need to get the faults cleared.
No really a DIY repair im afraid.
My 2005 Lincoln navigator has a new compressor and it lifts up but I must restart it to get it to lift. could you please tell me why
Have to restart what ? Vehicle ? Did you have the system check for code's ?
The four wheel air suspension system is comprised of the following components:
  • Service switch
  • Control module
  • Two front height sensors
  • One rear height sensor
  • Compressor and drier assembly (includes vent solenoid)
  • Air lines
  • Front and rear air spring and shock absorber assemblies
  • Four air spring solenoids
  • Compressor relay
  • Vehicle Dynamic Module (VDM) Diagnostic Trouble Code (DTC) Index NOTE: Repair all other DTCs before C1725 and C1726. Repair DTCs C1990 and C1991 last. DTCs Description Source Action B1317 Battery voltage high VDM Go To Pinpoint Test C . B1318 Battery voltage low VDM Go To Pinpoint Test C . B1342 ECU is defective VDM INSTALL a new VDM. REFER to Air Suspension Control Module in this section. SET the ride height. REFER to Ride Height Adjustments in this section. CARRY OUT the pneumatic test. TEST the system for normal operation. B2477 VAPS II steering assist curve not complete VDM REFER to Section 211-00 . C1445 Vehicle speed signal circuit failure VDM GO to Symptom Chart . C1724 Air suspension height sensor power circuit failure VDM Go To Pinpoint Test D . C1725 Air suspension front pneumatic failure VDM Go To Pinpoint Test E . C1726 Air suspension rear pneumatic failure VDM Go To Pinpoint Test E . C1760 Air suspension rear height sensor signal circuit failure VDM Go To Pinpoint Test F . C1770 Air suspension vent solenoid output circuit failure VDM Go To Pinpoint Test G . C1790 Air suspension LR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1795 Air suspension RR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1830 Air suspension compressor relay circuit failure VDM Go To Pinpoint Test I . C1840 Air suspension disable switch circuit failure VDM Go To Pinpoint Test J . C1873 Air suspension RF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1877 Air suspension LF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1881 Air suspension RF height sensor circuit failure VDM Go To Pinpoint Test F . C1889 Air suspension LF height sensor circuit failure VDM Go To Pinpoint Test F . C1897 Steering VAPS circuit loop failure VDM REFER to Section 211-00 . C1964 Air suspension compressor actual run time exceeded allowed run time VDM Allow the air compressor to cool down. CLEAR the DTC. REPEAT the self-test. C1990 New control module initialization (requires ride height calibration and pneumatic test pass) VDM REFER to "Clearing DTC C1990 or C1991". C1991 Plant ride height setting and/or tests incomplete VDM REFER to "Clearing DTC C1990 or C1991".
Ride height specification for 2002 Bravada and procedure on replacing sensors.Or where can I look on line for this information.
Air Suspension ??????
Air Suspension Description and Operation
Air Suspension
The primary mission of the Air Suspension System is the following for the rear suspension under loaded and unloaded conditions:
• Keep the vehicle visually level
• Provide optimal headlight aiming
• Maintain optimal ride height
The Air Suspension System consists of the following items:
• Air suspension compressor assembly
• Air suspension sensors
• Rear air springs
Important: The Air Suspension System must have a voltage supply of at least 12.6V to operate properly.
The Air Suspension System will maintain the rear D height within 4 mm (0.15 in) in all loading conditions and the leveling function will deactivate if the vehicle is overloaded. The side to side D height variation is maintained within 8 mm (0.31 in). After ignition is turned off, the air suspension control module (ASCM) will remain active for between 30 minutes and 2 1/2 hours. The system will exhaust pressure within 30 minutes after the ignition is turned off to lower the vehicle after unloading. In a temperature-controlled environment, the leakage of the complete load leveling system will not result in more than 1.4 mm (0.05 in) drop of rear suspension height at GVWR during a 24 hour period. If the outdoor temperature drops from +20°C (+68°F) to -5°C (+23°F), the rear D height may drop as much as 25 mm (1 in). However, the Air Suspension System should return to the specified D height when the ignition is again cycled to ON.
What is the problem ?
Diagnostic Trouble Code (DTC) Displaying
The Air Suspension system has an internal clock to prevent overheating if the compressor assembly is running for a prolonged period of time. If the system overheats, all leveling function stops until the system cools down. During this time, the indicator LED on the air inflator switch will be quickly flashing at a constant rate.
The other three diagnostic trouble codes are displayed with a blink code on the inflator switch LED. The Air Suspension Compressor Assembly shall begin to indicate the code when the condition to cause the code becomes current.
The number of the fault code shall be represented by the number of flashing pulses on the inflator switch LED. The flashing pulses shall have a repetition rate of 0.5 seconds and each code shall be separated by a 3.0 second delay. All codes shall be flashed in the order of occurrence of the fault. The blink code shall take priority over other processes that have access to the inflator switch LED. Refer to the following:
• DTC 001
• DTC 002
• DTC 003
Trim Height Uneven or Low ??????
05 Range Rover HSE inactive air suspension
Sorry computer controlled and it needs the dealer software to find the fault ,lot of money i would imagine to repair in the dealers
8helpful
2003 Yukon Denali has Service ride Control Warning..wat to do?
Hi Jose:
The first place to start is to have Ride Control Module scanned for trouble codes, this requires a high end scan tool. Most common problem is the air compressor in the rear or a height sensor. Here is how the system works.
Automatic Level Control Description and Operation
The RTD system is bi-state real time damping system. The Suspension Control module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system and electronic variable orifice (EVO) power steering system.
The Automatic Level Control system consists of the following:
• Suspension Control Module
• Compressor/Leveling Module
- Air Pressure Sensor
- Exhaust Solenoid
• Compressor Motor Relay
The objective of the Automatic Level Control System is to provide constant ride height at all load conditions. The Suspension Control module monitors body-to-wheel height, and vehicle speed.
The Suspension Control module will use the rear body-to-wheel displacements and vehicle speed inputs to keep the rear trim height of the vehicle at its desired level.
The electronic suspension control (ESC) system is bi-state real time damping system. The ESC module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system, if 1500 series.
The ESC system consists of the following:
• The ESC module
• The compressor/leveling module, if 1500 series
- The air pressure sensor, if 1500 series
- The exhaust solenoid, if 1500 series
• The compressor motor relay, if 1500 series
• The steering handwheel speed/position sensor
• The suspension damper solenoids
• The suspension position sensors
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
1helpful
The dashborad says suspension fault
Problems with the air suspension seem to be less frequent with the Sport than in previous Range Rover models, but they still do occur. One owner reports "Whenever my RRS is lowered to "access" level a suspension system fault message apprears.". Another reports " Had the RRS back less than 2 hours and another "suspension fault." Also kept receiving messages that the vehicle is raising slowly and vehicle will raise when system cools. Couldn't even drive because it wouldn't raise out of access mode. Anyway, back to the dealer. Picked the RRS up again today-dealer said the EAS compressor was faulty and replaced it. So far everything is ok." Overall, most of the problems seem to be related to bad suspension height sensors or bad compressors. Angus Wade of the Czech Republic had his suspension light come on when in Germany; it started yellow and then red, then disappeared when he stopped and restarted the engine -- and has not happened since. His dealer said they have seen this a bit.
Weak Compressor: An official Technical Service Bulletin (TSB) LS-204-004 addresses "ELECTRONIC AIR SUSPENSION (EAS) WARNING MESSAGE AND LAMP ILLUMINATION". This deals with the warning message "Suspension Fault - Normal Height Only" message appearing with the Air Suspension Warning Lamp on. Computer diagnosis shows pressure increasing too slowly or unable to pressurize, with no air leaks. The usual problem is the compressor exhaust valve sticking, causing an internal air leak when the compressor is active. The bulletin recommends renewing the air compressor (RQG500090 is the latest specification air compressor with a stronger exhaust valve return spring)and installing and updating the air suspension control module software using WDS disc 13 or later.
Suspension Fault Message (random): One owner reported getting random suspension fault messages on his brand new RR Sport purchased in June 2006, well after the fix was in for the weak compressor. His suspension Fault message and Suspension Warning Light (Amber) came on after 5 days of ownership. He stopped and restarted the car, which caused the light and message to disappear, but they came on again after 5 minutes. Later the same day, the warnings disappeared again.
I have heard that on 2006 models, EAS fault messages can be caused by an internal leak in the Air Suspension compressor exhaust valve. The fix is said to be replacing the compressor updating the software.
Hope helps.
The dashboard says suspension fault
Hope helps.
2helpful
Am receiving a message on my Range Rover 2004 Inactive suspension
Welcome to Fixya
Air suspension is currently in fault mode. It will have to be re-set by someone who has the Land Rover scantool (either a dealer or an independent shop). The EAS system is inaccessible with a regular OBDII scantool. The car will not allow you to control the suspension height (raise/lower/defeat) until the fault is cleared. Please see this link .
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2helpful
I have a 2003 range rover the air suspension inactive came on
it could be from many reasons...sometimes even the ABS system will cause this fault or even the Steering position Sensor. if it comes and goes then inspect your height sensors as the early version of the height sensors are getting weak and like melting so it gives wrong reading which cause the fault...offer more info. and you'll get your solution
4helpful
EXPEDITION REAR AIR RIDE PROBLEM
do you have just rear air suspension? here's rear only. 4 wheel different. Deler an run a diagnostic test with WDS machine and get fault codes.
The air suspension system is designed to improve ride, handling and general vehicle performance for static, on-road and off-road driving conditions:
  • Ride is improved by using an air type spring (the soft ride is inherent).
  • Handling is improved by maintaining constant vehicle attitude.
The system consists of unique rear air springs, the air compressor, air lines, air spring solenoids, height sensor, air suspension control module, attachments and associated signals derived from both driver and road inputs. With these components and signals, the air suspension control module commands changes in vehicle height that are necessary for the load leveling features.
The load leveling feature rear air suspension (RAS) systems shall automatically make adjustments in vehicle height so that the vehicle is always at trim height and constant front-to-rear vehicle attitudes are maintained over the expected load range of the vehicle. Adjustments in height that are necessary to correct height differences between the vehicle's left and right sides for the RAS system shall be restricted to what can be reliably achieved with one air suspension height sensor.
The system uses one air suspension height sensor, a steering sensor, generic electronic module (GEM) and other vehicle sensors to measure driver and road inputs. The system changes vehicle height using an air compressor, two air lines and the use of air springs with air spring solenoids.
The air suspension system holds vehicle height when the rear hatch or any door is opened. The system stores rear vehicle height the moment any open door is detected. The system then maintains this height regardless of the addition or removal of a load. The system will return to its commanded height when all doors are closed or the vehicle speed exceeds 16 km/h (10 mph).
Air Suspension Height Sensor
One air suspension height sensor is mounted on the vehicle. The air suspension height sensor sends a voltage signal to the air suspension control module. The output ranges from approximately 4.75 volts at minimum height (when the vehicle is low or in full jounce), to 0.25 volts at maximum height (when the vehicle is high or in full rebound). The air suspension height sensor has a useable range of 80 mm (3.2 in) compared to total suspension travel of 200-250 mm (8 to 10 in) at the wheel. Therefore, the air suspension height sensor is mounted to the suspension at a point where full rear suspension travel at the wheel is relative to 80 mm (3.2 in) of travel at the air suspension height sensor. The air suspension height sensor is attached between the No. 5 frame crossmember (upper socket) and the panhard rod (lower socket).
When the air suspension height sensor indicates that the rear of the vehicle is lower than trim under normal driving conditions, the air compressor will turn on and pump compressed air to the air springs. When the sensor indicates that the rear of the vehicle is raised above trim under normal driving conditions, this will cause the air to be vented from the air springs to lower the vehicle back to its trim height level
  • Uneven vehicle height
  • Circuitry.
  • Rear pneumatic fault.
  • Air compressor assembly.
  • Air suspension control module.
  • Go To Pinpoint Test I .
Top Land Rover Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Land Rover Expert? Answer questions, earn points and help others
