If you are able to advance the timer and get the machine to run and finish the cycle, then yes the timer is your most likely culprit, and yes the timer motor and timer are all one piece.
However if it does not complete the cycle and you are unable to drain the water out, your problem could be with the lid switch assembly, not the timer. Check the switch by looking for a tab on the right side of the lid that would (when the lid is closed) contact the switch mounted under the top of the cabinet. you should hear an audible click when the switch is depressed.
If you find it is the switch, please let me know and I will give you instructions on how to replace it.
