Amana PTH153B50AM Air Conditioner Logo
Posted on Oct 07, 2010
Amana PTH153B50AM AC works, heat doesn't. Is there a reset?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1018
Points
17
There might be a reset button on the heat protector / you just might have a bad heat protector or the sensor on the board could be burnt out
1 Related Answer
Anonymous
  • 4736 Answers
  • Posted on Jun 20, 2011
SOURCE: Amana PTH153B50AM AC & Heat
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity.
The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac
Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%.
Probably this one. Talk to your installer.
https://www.amana-ptac.com/products/ptac/hec154j
2answers
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
I have an amana ptac model pth153B50AM it does not seem to cool much at all but I do hear the compressor come on.Before i cost myself a couple thousand dollars can anyone tell me is this fixable?
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
1helpful
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
1helpful
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as...
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
We have amana heat / air units in our motel. I am not at the motel at thia time, but the manager has called me saying the unit was not getting warm and the digital lights say SP. can you tell me what SP...
Well, the solution is sort of a good news/bad news situation. It appears that the model number that you listed has been subject to a Safety Recall. This despite the fact, Amana no longer makes that specific model.
For further information and to make sure your specific model is included in that recall, go to
http://ptaccord.regcen2.com/
Only blowing out cold air on heat
Keep temp 30 degree and mode button in " Heat" Wait for 3 minutes. still problem, check heater-element/RV/Heater sensor.
2helpful
My unit just started blowing out cold air only when set on heat, what is wrong?
its on a lockout. there is a safety switch that is open do you have a multimeter? If not iside the furnace is a red reset push button if you push that chances are you had flame rollout and you need to call the experts that means either you have a cracked heat exchanger or a blocked or not working inducer
My unit just started blowing cold air only when its on heat, what can i do??
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat "position.If still no heat, check your heating sensor for closed circuit by an OHMsmetre.It it's with RV, check power to RV
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
