My problem is nokia 3110 c phone resicted undo problem
so plz give me this problem to solution
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the restriction code through online..........i will suggest the website http://www.unlock-zone.com/ which is doing good service .....you can approach this website.
Hi there! You will know for sure if your phone is lock or unlocked by inserting a sim card from other provider...For example if your phone is locked with at&t ..take out that sim card and put another sim card from a different provider...If your phone is locked the new sim card that you put in is not going to work. In this case you will need to get help from a specialized site who unlocks phones. You will need your IMEI number from the back of your phone and send it to them. I recommend you this websitehttp://unlockphonenetwork.com/ They are very good at unlocking phones! Hope that helped you! Cheers!
Nokia 3110 model when insert the sim card restriction undo problem
