Yes they can. Above the amplifier compartment you should see the output package. The output package is where the phono speakers are connected to but this can be used to provide output to extention speakers. E1 to E7 tappings left and right provide outputs at different voltages/wattage. E1 left and right is the comon (or ground connection) E2 is the lowest tapping and E7 is the highest. Most people would connect extention speakers to E3 or E4 left & right with the comon connections of the speakers to one of the E1's.
There is also connections for 70 volt line speakers, these are used where long cable runs are needed and the speakers are then fitted with 70 volt drop down transformers to the correct wattage of the speakers. These are available from most good electroic suppliers such as R.S. or Maplins etc.
Regards
Alan Hood
ami-man
Uk
