Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
I have the exact same problem
Identical problem
Same problem...
