You'll wanna check out:
ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart
Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to
connect your router, modem, and PC(s); configure your wireless settings; and enable wireless
security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your
Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the
Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates
many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see
"Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac,
are using a Linux operating system, or are technically knowledgeable, select this option. If you
choose to use this option and install your router manually, for best results, install and set up
your router in this order:
Failure to follow these guidelines can result in significant performance degradation
or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind
another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation
method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless
Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet
Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your
wireless network (see "Configuring Your Wireless Network" on page 21)
I think I tried everything. The smart wizard always makes a mistake when configuring my network. It assumes that my IP is fixed while in fact it is dinamic. I have to configure my network manually, otherwise it is not going to work for more than 10 minutes.
I managed to configure it 3 weeks ago manually and it stoped working again. I tried to reconfigure it manually and the router worked for 1 hour and died again. When a tried to restart the router it freezed and could not do the tests that are usually done in the starting process. The power light turned on amber and the router could do nothing more than that, I noticed that when it happens I must disconnect the router from the power and wait a few hours before trying to reconfigure ot again. If I try to do it before this "waiting period" the only thing that I will get from the router is an amber power light turned on. Now I will wait some time to try to reconfigure it manually and pray.
