Heating Steam The steam boiler has fallen below set point... could be tripped hi -limit .. steam relay faulty
Firstly, try to reset the overheat Klixon on the side of the steamboiler. Sometimes they can trip out if they overheat. Once you open the lid cover. You will see the round over heat stat with 2 wires going to it and right in the centre there is a little button that will be popped out, this needs to be reset by pressing it in.
If this is not tripped out, then you need to check the boilers element for resistance using a multimeter to make sure it is ok, I think on those boilers it should be about 45ohms but i'm not 100% sure on that figure? The hot water boiler and steam boiler on these machines are the same so you can check the resistance is the same on both.
If this doesnt help, please provide more details of the fault and I can try to further assist you.
Please dont forget to vote if you liked my answer
thanks
