I have a model 58915.602 roof-top air conditioner that also uses an analog signal and it broken. Where do I get a replacement or is there a replacement available?
Why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
See as the drain goes downwards so water doesnt back up and spill over the drain pan of the evaporator and you can try a shop vac on the drain pipe to make sure no bugs or spider as nested it there usually it work pretty well for me if all fails you will have to disassemble and inpect visually the drain pipe/hose and that no icing occures on tubes outside of the area covered by the drain pane wich would most likelly be du to a freon leak, good luck!
My Coleman Roof Top A/C Is Not Cooling Properly. I checked fore a place to put Freon ( or coolant) and did not find Any. Do you have any suggestion's
