You dongle probably has a cap on it. Remove the cap and you should see the USB connector.
Now all you have to do is locate the USB port on your computer and plug it in. If it does not seem to fit, try flipping it the other side and see. All USB Bluetooth dongles come with a USB connector (Thats why they are called "USB" dongles)
Here is a pic of what a USB port looks like on youi have purchased a bluetooth - b867f75.jpg:
Should your dongle not match the image above, kindly try to send a pic or give me the make and model, and I will assist you further.
Take this to one of the 3 >radio shack /circuit city/fry's electronics They will instruct you and supply you with the cable you will need.You don't bring your computer.
Hello there.
I have found a picture of the back of your computer. Please see below. The picture is a little small im sorry.
A bluetooth dongle connects over the USB port in your computer, while you have some slots in the back you should have some in the front as well. They look like this:
Hope this helps.
tks for advice but my dongle does not have cables/plugs coming from it. do I need an adaptor?
tks for reply. my dongle does not have any cables/plugs coming from it. do i need an adaptor?
sorry this does not answer the problem. In no way can I plug this :dongle: into my compoutor without some sort of adaption.
problem solved found my way into the dongle which was not visible and given wrong advise by shop i got it from . many tks all.
