I got a new Hotpoint side by side one. The water tastes salty a bit and when the fridge dispenses the water, the water is cool for a few seconds then turns warm then cool again. Any opinions?
It is possible that the water softener is not functioning properly and causing the water from the refrigerator dispenser to taste salty. Here are a few things you can try to fix the issue:
Check the water softener settings: Make sure the water softener is set to the correct salt dosage and regeneration frequency. If the settings are not correct, it can cause the water to taste salty.
Check the water softener filter: The filter in the water softener may be clogged or dirty, causing the water to taste salty. Clean or replace the filter as needed.
Check the water softener resin: The resin in the water softener removes hard water minerals and can become exhausted over time. If the resin is exhausted, it can cause the water to taste salty.
Check the water softener bypass valve: The bypass valve allows you to bypass the water softener and use untreated water. Make sure the bypass valve is not accidentally left in the bypass position.
If you are unable to diagnose and fix the problem on your own, it is recommended to have a water treatment professional take a look at the water softener. They will have the necessary tools and expertise to properly diagnose and repair the issue.
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Do you have a water softener? It's possible the softener was in soak when you used the water dispenser. That would explain the "salty" (hi sodium) water taste and thena retrun to normal later.
Also, if you get your water from a muncipal well, they may have been experiencing a problem at the time with higher than normal sodium content.
You said, Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
replaced the copper tubing which delivers the water to the fridge and
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
door in July 2008. The fridge has a filter. A few weeks after the
fridge came the water and ice started tasting really bad, unlike any
bad water taste I have ever tasted. And your tap water is fine. The bad
taste appears to be random. Sometimes you get a cup full of nasty water
and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions! Did you do this before connecting the water line to your fridge? "Place the free end of the tubing in a container or sink, and turn ON the main water supply. Flush the tubing until water is clear. Turn OFF the shutoff valve on the water pipe. Coil the copper tubing."
Whirlpool remedy Off-taste, odor or gray color in the ice 1.Are the plumbing connections new, causing discolored or off-flavored ice? Discard the first few batches of ice. 2.Have the ice cubes been stored too long? Throw old ice away and make a new supply. 3.Does the freezer and ice storage bin need to be cleaned? See “Cleaning” or “Ice Maker and Storage Bin.” 4.Has food in the freezer or refrigerator been wrapped properly? Use airtight, moisture-proof packaging to help prevent odor transfer to stored food. 5.Does the water contain minerals (such as sulfur)? A filter may need to be installed to remove the minerals. 6. Is there a water filter installed on the refrigerator? Gray or dark discoloration in ice indicates that the water filtration system needs additional flushing. Run additional water through the water dispenser to flush the water filtration system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to 7 minutes initially). Discard discolored ice. Let me know what works, Thank You , HUUUM!!
Hello, does your unit have a water filter? Has this been replaced? If not I would remove the filter - flush the unit by dispensing as much water as you can to get fresh water into the system. Do you use the water much? Once you flush it, I would keep flushing it every time you get a chance for the next few days - without a filter in it and then replace the filter. Do you have well water or municipal water? Check the line in the back of the unit - anything unusual there? Good Luck, I hope some of these suggestions help you! Dr. Know
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
