Nokia 5310 Cellular Phone Logo
Posted on Oct 06, 2010
I have nokia 5310 mobile in my mobile my volume slider button is not working so i can't increase my volume the audio is so tiny.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4015
Points
8
I have nokia 5310 mobile xpress music, once i remove the memory card and inserted, now it's asking password but i din't remember of setting password for memory card, pls help me on urgent basis or re-direct to correct party to liaise with..
Regards, Asha
1helpful
2answers
Nokia 5310 keys not responding
If resetting it via the power button and thus returning it to factory defaults does not work, you may be looking at a problem requiring a technical repair, such as replacing the IC board. https://repair-mobiles.com/tag/5310/
But I'd first confirm it has taken a full charge.
https://www.nokia.com/phones/en_us/support
2answers
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
I cant increase or decrease volume on my nokia 5310 xpressmusic. What can I do?
If both the volume does not work there is no other way.The only thing we have to do is to change the Pata(Flex).So, contact mobile repairing shop Or refer the image raingamj_31.jpg
Thanks for visiting fixya
5helpful
3answers
I can't able to decrease the volume but i can increase the volume
c, when u decrese the volume, then volume level appeares on screen. That time, simply press up key. Volume will increse.
3helpful
My nokia 5310 fell down and volume control is not working.. i am not able to adjust the volume.. how can i make the volume control work.. or how can i increase or decrease the volume without using volume...
hi
either your volume button get damaged or the software gets corrupted in your phone.. change the volume button and format the phone.this willl fix your phone..
thank you
My mobile hearing volum is very low what can i do?
Hi!
Do you have a button on the side off the phone for controlling the volume, or on some phone you can use the button for UP to control the Volume of your phone. While on call press on that button to increase the audio volume.
Hope this helps
2answers
My nokia 5310 handset volume is not working.
sir when you answering the call then increase the volume button to increase the volume of the handset
Unlock code for nokia 5310
http://www.unlocking4u.com/nokia-5310/rs6wp9/ will give you the unlock instructions for your nokia mobile.
Nokia 5310 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 5310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5310 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5310.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5310 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5310 mobile phones locked to the network Fido in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5310
Each Nokia 5310 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5310 mobile phone using the form above.
1helpful
I need an unlock code for nokia 353657011043528 please
Hi michael_rodg,
http://www.mobileunlocksolutions.com/ will provide you with an unlock code for your Nokia 5310 mobile. The instructions are as follows:
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
