Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
Posted on Oct 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCM-17v8 monitor has scrolling lines. I have tried all resets, settings, etc. If I turn the brightness up to 100% the scrolling lines go away. But after a few minutes, I get a white screen.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
  • Posted on Oct 06, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
0
Helped
44947
Points
825
Lopse board connection try to resolder the main board.
1helpful
2answers
Lcd-17v8 monitor power won't stay on. westinghouse monitor
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
2answers
I have a 17" LCD Monitor - LCM-17V8. When I turn
Hi, it seems to be an issue with your monitor's backlight not working properly. Just to be sure, try using a different monitor on the same exit of your VGA, if that works, my supposition is confirmed. In case your monitor is still under warranty, just send it to Westinghouse support center, otherwise I'm afraid you will have to buy a new one. Hope it helped, Franz
2answers
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
LCM-17v8 Monitor Blacks out after a few minutes. Unplug power source and you have display again, for how long is anyones guess. Any suggestions
Does this happen ONLY when connected to YOUR computer,
or does this happen when conected to some other notebook/desktop?
If the former, your computer is entering "power-save" mode,
after a few minutes of inactivity. Just "wake-up" your computer,
and it will wake-up the LCD monitor.
If it is the latter, then you have a "hardware" problem with your LCD monitor. Take it to a qualified technician for trouble-shooting.
Westinghouse monitor lcm 17v8 will not power on it just sits there and blinks
mufdvr6942, the "switch-mode-power-supply" is in shutdown. Have a technician evaluate (inspect) it. Do that if monitor is less than 4yrs old.
Also visit youtube and search and view longer (8-12min) vid clips of LCD monitor disassembly or LCD repair FYI 12fixlouie
1helpful
2answers
What causes vertical lines on screen, some lines are thick and some are thin and appear over the task bar, they are across the entire screen.
They are static lines. They can be caused by a variety of reasons, damage to your monitor, damage to your vid card (perhaps it was got a little too hot?), ive seen this issue also with overclocked, try resetting to defaults if so. Also try reinstalling/updating your current display drivers. If you have an integreated video card it could be that your motherboard got hot and perhaps damaged it. If you have a spare vid card or something else you can hook up to try, and it still has the static lines, then it is your monitor for sure.
2answers
MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY WHITE AFTER FIVE MINUTES!
Generic problem for all Monitors Benq lcd Displays only white var g_tryMail = 0; MessageRate.ThreadID = 421124; MessageRate.ProductID = 689784; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 2 users posted by MatrixNet on Mar 02, 2008
I have a BenQ FP791 17 in LCD. I was working until one day I turned it on and it now only displays an all white screen. I plugged it in to another computer, same problem. I can add it as a second monitor to windows but all it displays is white. Windows finds it and the mouse can move over to it but I do not see anything. I am handy with a soldering iron, but not nessisarily diagnosing electronic problems.
Comment posted on Oct 26, 2008I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
2helpful
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
1helpful
2answers
Monitor (model #LCM 17v8), has suddenly gone "white".
Just done fixing 2 of these "white out" (model #LCM 17v8), monitors. Contact me at [email protected] for solution.
Thanks
Top Westinghouse Computers & Internet Experts
Paul Bade
NOEL
NOEL
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
