Question about Dell Studio 15 Laptop
How do I manually eject cd tray of dell studio 1558? Eject button doesn't work. Thanks.
  • 1,768 Answers
Here is the Dell service manual page where it shows the disassembling of the Dell 1558.
You will have to remove the DVD module to eject the DVD
Procedural steps are on this page site.
http://support.dell.com/support/edocs/systems/studio1558/en/index.htm
Posted on Oct 05, 2010
    New Friend:
On the DELL Studio 1558 there is an eject button, top row of keyboard, 4th button in from the right side. Its an orange button with an up arrow on it. Press and hold for a few seconds and the CD/DVD will pop out.
Posted on Jan 05, 2013
    New Friend:
Is it possibly Fn-F10... this works in boot up mode, even when in a bootup loop for the Dell I have here..
Posted on Mar 02, 2012
    New Friend:
Thank you! On the model I'm working on it's the 8h key, top row of keyboard coming in from the right. It worked while the machine was in boot up mode. POS
Posted on Aug 03, 2013
    New Friend:
Thank you very much Mr.Sampson.I was about to send my laptop to technical support.That really help!
Posted on Feb 19, 2013
SOURCE:
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Cd jammed in a dell pp31l
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Jan 20, 2012 | SIB USB External CD-ROM Drive for Dell...
Cannot find the icon to eject cd from Dell Studio 1558? how can I eject the cd disk?
You can eject cd's by right clicking on Computer (from your Start Menu) then right click on the drive you'd like to eject. There should be an option to do so.
May 10, 2011 | Dell Studio 15 Laptop
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
I forgot how to eject a cd from my new Dell Studio 15
You can uses the button on the CD drive to eject the CD. If that doesn't work you can also right click the CD drive icon from "My Computer" and select "eject".
Mar 19, 2011 | Dell Studio 15 Laptop
The eject button will not eject the cd
Hi there, this is a common problem encountered by our CD ROM's. if you want to eject the cd tray, just go to My Computer and right click your cdrom drive then click eject. thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 06, 2010 | Dell Studio 15 Laptop
Where do I find the eject key to eject a cd from my Dell studio laptop?
There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject.
If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list.
The tray should now eject.
Regards.
Jan 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
CD wont eject from drive
Have you already tried to mannually open the tray, by inserting a thin straight object (like a unbent paper clip) in the manual eject hole on the optical disk drive? The hole exists for that pupose.
Jul 18, 2009 | Dell Studio 15 Laptop
CD Drive
Studio systems does not have any tray because it uses a slot. Theres no mechanical eject button. You may eject it using the Fn+F10 key on your keyboard.
Jun 14, 2009 | Dell Studio 1737 Laptop
Ejecting cd dell studio 17
It's very annoying they don't tell you how to do this. I looked here for the solution, then found it myself.
You have to depress the blue Fn key and simultaneously depress F10. Notice that that key has a blue "eject" symbol on it.
Sep 26, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Studio 15 Laptop Logo
8,993 people viewed this question
Ekse
Clive
Clive
