Brother HL 2140 Laser Printer Logo
Posted on Oct 05, 2010
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1426
Points
12
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
4helpful
I have brother Printer HL 2140 . This printer become offline automatically after some time & does not print. how we can solve the problem.
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
1helpful
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
5helpful
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
2answers
Brother HL-2140 won't print from Firefox (or IE)
am not very sure but i think u should try go to printers and faxes through control panel open it and right click on your printer and select print on line
2answers
Blank paper
Make sure you are letting it warm up long enough.
Brother HL-2140 Support
Norman Weimar
Norman Weimar
k24674
