Question about Opticon OPN 2001 Mobile Data Collector Barcode Scanner
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the product. I held both buttons down to clear the device again red line is there but no beep. tried to download to see if it was scanning but not beeping, scanner was empty.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Posted on Aug 27, 2011
6ya staff
SOURCE:
A black line on the scaned page
If light going around the paper, and if upper white paper don't cover it, this part will be black. Try to cover with some part of white paper around. If you have black line in the middle of scan, you have hardware problem with scanner (or old buggy driver). Try to update scanner driver.
Aug 24, 2011 | Office Equipment & Supplies
What is the procedure for scanning.
insert the page for scanning to scanner,
open soft ware for scaning or open ms word give scan files from scanner or other capturing devices
select area for scaning
in some printers have on appication for scaning like hp scx-1350
Mar 18, 2011 | Office Equipment & Supplies
Documant did not scaning and out put image red colour.
go to properties of the device and put on cmyk or rgb color mode to scan proper
if solved the problem
put ratings to me
Dec 15, 2009 | HP ScanJet 2400 Flatbed Scanner
Scan stops in middle of the task
please you go the scaner in scan aply when you aply a manual select and scaning page custom size select and try scan is ok.
Oct 23, 2009 | HP PSC 1410 All-In-One InkJet Printer
When I scan a picture, the resulting scan is
scaning time use enlarge option in scaning software
Apr 18, 2009 | HP Scanjet 5470c Flatbed Scanner
Need a repair & instruction manual for the hp scanjet 5370c scane
Go to http://www.hp.com and input your scanners model number and download the user manual. HP doesn't let users download repair manuals for their products
Good luck.
Nov 13, 2008 | Unitech (FPR010)
My scan doesn't work
If the power led not glows then check the power line and adapter.
If glows, open the scanner lid, press the scan button see the scan light (the lengthy tube) is on and the scanning part is moving.
The high resolution selection may some time hang the system.
Look in the task manager whether the scanner is working.
Reinstall the scanner.
Apr 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
The filmholder stop under scaning ?
According to Konica Minolta the driver you are using is not Vista compatible. You might look into downloading VueScan http://www.hamrick.com/ which will allow this scanner to work in Vista.
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
WON'T SCAN
Did you have things apart far enough to mess with the scanner.  The scanner should move to one side when it first goes on, and then trip a sensor (home position sensor).  Also, the scanner is probably belt or cable driven.  Check to see that the belt is somewhat tight, and that the gears and pulleys leading to the scanner motor are in place and not broken.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Opticon OPN 2001 Mobile Data Collector Barcode Scanner Logo
594 people viewed this question
Top Opticon Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
