Question about Samsung HL-R6167W 61" HDTV
For the last couple of months there's a buzzing sound when the TV is powering up. A couple of times I list picture during a show but, I powered down and the picture came back. Now, I don't even get a picture it simply gives me the beeps and then lamp flashes. After a while trying to power up, I get the lamp flashing, along with the standby/temp, and timer.
  • Samsung Master
  • 5,138 Answers
You could have 2 things Color Wheel and Lamp needs to be replaced Color wheel is what Making buzzing sound,
Go to Encompass Parts Distribution 1-800-638-3328
Type in your Model # they will have list of Parts/Supplies
Posted on Oct 05, 2010
SOURCE:
LG 50PZ750-UG Intermittent picture and sound.
It is likely the best thing to do here money wise is replace the TV.
Aug 25, 2016 | LG Televison & Video
After a couple months or so of taking 15-20 minutes for the picture/sound to show up the set just died one day during viewing time and now won't turn on at all and nothing is blinking.
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Will solved the power problems.
Apr 21, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Sep 03, 2009 | Samsung Televison & Video
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Sony TV goes to standby - constant red light
The Power Supply has gone. It needs replacing.
Jan 04, 2009 | Televison & Video
Quasar 1989 tv makes a buzzing motor sound
Hi and welcome to FixYa,
Initially, if you have confirmed that the source of the buzzing sound is from inside the TV, then that would indicate a component about to fail or would need attention. Let us try process of elimination:
  • tuner - most unlikely, the tuner is responsible for selecting the channel. No component/part of the tuner could make such a mechanical buzzing sound;
  • speaker(s) - most unlikely, the speaker could have a buzz but generally would not affect the video nor cause snow (weak TV signals);
  • transformer - a strong possibility although without knowing the exact model, at most generic ideas; power transformer, flyback transformer, horizontal drive transformer (unlikely);
  • arcing - another strong possibility. This could be caused by damp, dusty surroundings of the components especially at the FBT area. Another area that could have adverse effect when dusty/damp would be the anode cap.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Televison & Video
Power but no sound or picture alot of the time
the fault you are describing sounds like what we in the trade call dry joints, basically where components are soldered into the circuit boards in manufacturing, the joints become brittle and crack thus forming a poor connection which can vary with heat. well worth repair may need a couple of electrolytics aswell but i could do the job myself safely for under £100.
Jan 18, 2007 | Hitachi 60CX29B TV
No sound or Picture, Just a hissing sound.
well what sounds like happened is you blew up the tube in it. have you unplugged it from the wall and just let it sit some times that helps because what will happen is there will be a Electrical build up and it won't work right. an other thing you might want to do is hit the Degauss button on the remote. plug some sort of video signal into it and go through the inputs to see if that helps, mine did that every thing would just be black but i plug in my video camera it would detect it and make sure that the audio cables are plugged in these TV might just be that old that they have to have both audio and video in order to work.
Nov 27, 2006 | NetTV DTV34XF3 34" TV
Samsung HL-R6167W 61" HDTV Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
