My Elna Stitch Craft 4000 sews very small stitches even after I adjust the length?
It sounds like there might be an issue with the settings or mechanism of your Elna Stitch Craft 4000 sewing machine. Even after adjusting the stitch length, if it continues to sew very small stitches, there are a few things you can try:
1. **Check the Stitch Length Dial**: Ensure that you are adjusting the stitch length dial correctly. Sometimes, the dial may not be turning properly or may be stuck, leading to the machine sewing at the same small stitch length regardless of your adjustments.
2. **Clean and Oil the Machine**: A sewing machine that hasn't been cleaned or oiled in a while can have issues with stitch length consistency. Follow the manufacturer's instructions to clean out any lint or debris from the machine and oil the necessary parts.
3. **Inspect the Feed Dogs**: The feed dogs are responsible for moving the fabric through the machine. If they are not functioning properly or are obstructed, it can affect the stitch length. Check for any debris or damage to the feed dogs and clean or replace them if needed.
4. **Check the Bobbin Tension**: Incorrect bobbin tension can also cause irregular stitch lengths. Make sure the bobbin is correctly threaded and that the tension is adjusted according to the machine's specifications.
5. **Test with Different Fabric and Thread**: Sometimes, the type of fabric or thread being used can affect stitch length. Try sewing on different types of fabric with different threads to see if the issue persists across various materials.
If none of these steps resolve the problem, it may be necessary to have the machine inspected and serviced by a professional technician. They can identify any underlying mechanical issues that may be causing the small stitch length problem.
