Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was
not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
The EFO code is a general error thatIs caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear it run the machine through a quick cycle or normal cycle but without using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear it you can remove the back cover of the pump an dremove the hose. Inspect them and clean them if nay obstruction.
Please accept the solution if the information provided has been helpful.
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out. 2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle. You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
