Keep your scooter on charge doesn't sound right. Usually, eScooters take 3-4 hours for charging and many chargers have a red while charging. These chargers turn the green light on when they completed the charging. Here, you can also read more tips about the take care of your e-scooter or e-bike https://www.insurance4ebikes.co.uk/looking-after-your-e-bike/. However, according to auto experts battery should be full all the time.
Turn the scooter's power switch to the OFF position.
Connect the charger's plug to the charging port on the scooter.
Plug the charger's power cable into a power outlet.
When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
Times recommended for your scooter.
Stop charging when the LED light is completely green.
Disconnect charger from the scooter, then from the power outlet.
Run your scooter before riding it to verify the battery charge.
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
If you use the scooter then charge it. You need to charge the scooter at least once a week even if you don't use it. More importantly is that you charge the scooter for at least 8 hours at a time. If you charge it less then it will start killing the batteries.
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
