Question about La Crosse Radio Controlled Atomic Clock
I have the wall clock with pendelum. it stopped i put in new battery but cant seem to get it started
  • 11,800 Answers
The clock must be perfectly level - check that with a spirit level. If you don't have one then a wire with a weight attached should do.
When you swing the pendulum for the first time try to swing it at it's normal movement angle, if it's too high or too low the mechanism will not be able to sync with the quartz and the clock will not work.
Posted on Oct 04, 2010
SOURCE:
Troubleshoot for my new england clock mantel,wind-up pendelum clock?
Your spring may have been overwound. There are several YouTube videos that show you how to release an over-tightened main spring.
Nov 28, 2017 | Home
Put new batteries in Howard Miller battery operated wall clock now hands have stopped working. What's my problem?
Batteries were put in the wrong way?
Contacts are not clean?
Batteries were not fresh?
Clock is broken?
Mar 23, 2017 | Home
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Elgine Battery Wall Clock
When you removed the battery, were the terminals corroded? If so, clean the terminals on the clock to remove any corrosion.
When you removed the battery , was it difficult to remove? Sometimes during removal of the battery the wires that connect to the termimals will break or come free. If you can see the wires that are supposed to connect to the terminals, make sure they are making good contact and that they too are not corroded.
Good Luck.
Apr 16, 2008 | Audio Players & Recorders
La Crosse Radio Controlled Atomic Clock Logo
107 people viewed this question
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
