After setting gas oven to bake at 400. It took 25 min. to buzzer the temp was 442. 15 min later it was 370. 10 min later it was 439. 25 min later it was 313. 10 min later it was 439. 35 min later it was 286. 15 min later it was 433. 47 min later it was 253. Is this normal? What could be wrong?
Thanks
This may be due to the fault in thermostat
first check the thermostat and also check whether there is any loose connections inside and correct it
you can get manual for
PLGFMZ98GCAin this links
http://www.extremeease.com/
http://www.knowledgestorm.com/search/key...
thanks for using fixya
You may press the accept button on my solution if you are satifyed.
