Question about Kirby Ultimate G Bagged Upright Vacuum
Thank you for the detailed explanation regarding the kirby vacuum functions, but we would like more information about the exact shampooing instructions. in explanation we would like to know exactly what solution and in what quantity to apply first to the fabric... how long we need to let it soak in.... and how to remove the stains using only our kirby vacuum witjh shampoo attatchment from start to finish...
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Your best to go onto youtube for instructions on how to shampoo.
Posted on Aug 24, 2017
SOURCE:
b0sslady2001
  • 357 Answers
SOURCE: shampoo
Here is the answer in my online guide....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope it helps...
Marci
Posted on Oct 25, 2007
  • 75 Answers
SOURCE: Kirby Dry Foam Shampooing
I am not a big fan of Kirby Shampooers, but if you have one you are having problems with.... Try vacuuming out the machine itself.... I know it sounds weird, but in many cases that has actually helped.
Posted on Jan 14, 2008
b0sslady2001
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
RockyNR1
  • 324 Answers
SOURCE: need help attaching vac hoses to shampoo couch.
Here are the instructions. But please be very careful and shampoo an inconspicuous area prior shampooing entire piece of the furniture.
Posted on Nov 04, 2008
  • 112 Answers
SOURCE: dont know how to put the shampoo system together on my kirby g6..
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
Posted on May 23, 2009
Can't figure out how to attach hose from plastic shampoo container to vacuum
The below link is to a Kirby site that provides a video for attaching the shampooer. Very informative.
http://www.kirby.com/Portals/0/videos.html
Jan 22, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do we convert our Kirby G5 vacuum into the shampoo part?
Hi There,
Here's a link to a very helpful video that explains step by step the exact procedure to convert your Kirby into a carpet shampooer.
If you ever need to purchase the dry foam shampoo made specifically for Kirby vacuums, we have a great selection and prices (free shipping both ways):
Kirby Carpet Shampoo's & Cleaning Products
Here's the videorepair link:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope this was helpful to you. If it was helpful, please be so kind and leave some feedback, thank you.
Chris J.
GoVacuum.com
Apr 17, 2010 | Kirby G5 Bagged Upright Vacuum
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I can't find my manual must have got lost in our move and I don't know how to use the shampoo part of the kit
best most detailed explanation I have found anywhere.
Good luck and I just did mine and the rooms look **** and span
Mar 20, 2010 | Kirby G5 Bagged Upright Vacuum
How do i use my carpet shampoo system?
Please copy and paste the address below to the address window to obtain instructions for your Kirby Shampooer.
Hope this helps :)
Thank you for using Fixya!!!
May 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dont know how to put the shampoo system together on my kirby g6..
Hope this helps :)
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
Shampoo furniture
I have had a Kirby for over 20 years and yes you can shampoo your furniture. You do it just as you would your stairs or as if you were spot cleaning. There is really nothing to it.
May 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to shampoo stairs
HERE is the manual
When rating my solution rate the clarity of the explanation NOT whatever you like Kirby stair shampoo system. I do not believe this is the way to shampoo either but this is not me who designed it. Will get the job done but it is a lot of scrubbing and rubbing.
Good Luck
Rocky
Mar 24, 2009 | Kirby G5 Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
57 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
