Linksys SRW2016 (745883562435) 16x1000 Mbps Networking Switch Logo
Posted on Oct 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it does not work. Remember i have done inter vlan routing on cisco switches and router earlier so configuration is not a problem its just that i cant get linksys switch configured correctly. Please help.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2907
Points
7
On the linksys switch set the trunk port connecting to the cisco to 'general'. Match the native vlan on the linksys switch port with the cisco. The native vlan on the linksys will be set to 'untagged' with any other vlans that you want passing over the trunk set to 'tagged'.
You probably have a good grasp of how to do trunking on the cisco. The linksys does it, lets say, differently.
Anonymous
Level 2:
Scholar:
  • Expert 97 Answers
  • Posted on Oct 17, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
97
Questions
0
Helped
31346
Points
219
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
How many VLANs are supported by a Cisco 1921 router?
There are 2 ways that the 1921 can support vlans.
If you purchase a 4 or 8 port switch module (EHWIC-4ESG or EHWIC-D-8ESG) for the 1921, the switch module can support 16 vlans.
The other option is set up one of the routed ports with sub-interfaces (one sub-interface per vlan) and attach the port to a trunk port on a switch.
You can create up to 1200 sub-interfaces on the 1900 (although I doubt you'd need that many without maxing the performance specs of the router)
tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 • Computers & Internet
tip
Cisco 1800 Series, Business Router for Small to Medium Sized Business/Enterprise
Cisco 1800 Series Integrated Services Routers, the next evolution of the award-winning Cisco 1700 Series modular access routers, own more advantages than the formers. Cisco 1800 series, ideal for small to medium-sized businesses and small enterprise branch offices, enable businesses to reduce costs by deploying a single, resilient system for fast, secure, delivery of multiple mission-critical business services, including data, security, unified communications, wireless.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series router</a> has several models including 1801, 1802, 1803, 1811, 1812, 1841(most popular), 1861, all of them have some common features: a. Designed for small businesses or branch offices and to offer secure wireless networking; b. Multiple performance options based on local, remote, or broadband connections; c. Integrated security including encryption and protection against hackers; d. Virtual private networks for linking to partners, suppliers, and remote offices; e. Multiple options for adding reliability and option for reduced costs by using power from network cabling; f. Software upgrades to add new features and functions, and integrated switching capabilities.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series</a> router has several models including 1801, 1802, 1803, 1811, 1812, <a href="http://www.router-switch.com/cisco1841-p-97.html">1841</a>(most popular), 1861. You can check details of every type as follows:<br />The fixed platform models (1801, 1802, 1803, 1811, 1812) include multiple WAN interface options, plus:<br />Up to broadband speeds<br />Eight 10/100 Mbps built-in switch ports with optional Power over Ethernet (PoE), for providing DC power to network devices such as IP phones<br />Up to 50 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1841 is a modular platform with a wide range of interface options, plus:<br />Up to T1/E1speeds<br />Up to four 10/100 Mbps built-in switch ports<br />Up to 800 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1861 is a modular platform built on a fixed base with a wide range of WAN interface options, plus: <br />Integrated Cisco Unified Communications Manager Express or Cisco Unified Survivable Remote Site Telephony for call processing<br />Cisco Unity Express, for voice messaging and automated attendant<br />Integrated LAN switching with Power over Ethernet (PoE) expandable through Cisco Catalyst Switches<br />Onboard voice ports for PSTN, PBX, and key system connections<br /><br />With Cisco 1800 Series integrated services routers; you can lay the foundation for future growth and prepare for voice, video, wireless, and security solutions tomorrow. <br /><br />If you want to know more about e about the certain type of Cisco 1800 series, you can visit the list of Cisco 1800 router series, prices also offered.<br /><br />
on Jun 30, 2011 • Computers & Internet
Cisco 3524 not receiving vlan info
Try this http://tools.cisco.com/search/results/display?url=http%3a%2f%2fwww.cisco.com%2fc%2fdam%2fen%2fus%2fproducts%2fcollateral%2fswitches%2fnexus-4000-series-switches%2f6701_catswitch_guide_v7_r5.pdf&pos=5&query=WS-C3524-XL-EN
ProCurve 1800-24G (1010071458): how to create vlan's at hp 1800g24 switch...
You will have to log into the switch, select VLAN and create a VLAN.
http://h17007.www1.hp.com/us/en/support/converter/index.aspx
I have the Dlink 1700 series router i need to add in 2vlan.its possible
Usually you can create VLANs on routers. On cisco 1700 (based on ur image) you can create multiple VLANs.
If you can give me the exact model number on dlink i can help you to fix the problem.
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Does HP ProCurve 1800-24G 24 Port Switch can act like a cisco router e.g. 2800 series or others
The Procurve 1800 SWITCH series supports 802.1p, 802.1q VLANS, 802.3ad LACP, 802.3x Flow control, RFC1534 DHCP/BOOTP interoperation, the Cisco 2800 series is a ROUTER and dependant on its IOS version will support a multitude of routing/security features that the Procurve just isnt designed to do.
1helpful
Routing
show ip int brief This will show you the available interfaces and type.If you want to create on Fa0/0 for example the config will be as follows:
On configuration mode type
Interface fa0/0.[vlan Id]
encapsulation isl | dot1q [Vlan id]
Assuming you are using dot1q and terminating vlan 200 The config is as follows
int fa0/0.200
encapsulation dot1q 200
ip address --------
on Gig Port
Int gi0/0.200
ip address
The encapsulation used should match the switch trunk.Default encapsulation is isl on cisco switch.If you are connecting another vendor use dot1q encapsulation.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
