Hisense LHD3204US 32 in. LCD HDTV Logo
Posted on Oct 03, 2010
When I moved out of my parents house I put a password on my TV and when I moved back in I don't remember the passeord. Now i am un able to watch anything thats not un-rated or rated PG
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
161
Points
Hi,, which tv is it ??
1helpful
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
6helpful
Can't Reprogram the TV Guardian code
Forgotten Parental Control password can be bypassed/cleared by entering "788444" even if 4 digits "----" appears, then press ENT to clear the current password. You can then enter a new parental control password.
3helpful
Truetech tv
I had the same problem with my TruTech TV after i recieved cable from Time Warner Cable. We aslo thought it was the cable but it was obviously the TV, so my boyfriend went to the options and went to change password and put 0000 or 1111 and it asked to pick a new one so he just put 0000 again as the new password then he went to V-Chip and it asked for the password and that takes you to parental control and then you just true it off and your offical back in business and youll be able to watch anything you want now
150helpful
14answers
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
2answers
Parental control password
Try using the code 7-4-4-4. It should clear whatever they put in and then you can put your own in.
Input password
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
5answers
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
1helpful
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Locked out
to over the lock the eprom needs to be taken out and resolder back that will reset the parental lock when ever you put in a code use a eamily member birth date yours or a friend birth date or a house address
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
