Soyo Atlas DYLT3212 32 in. HD-Ready LCD Television Logo
Anonymous Posted on Oct 03, 2010
I cant find a code for my Prive L C D tv replacement remote
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
688
Points
I found a RCA universal remote which in code search found the code for my prive 26" tv.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
688
Points
If you do find the code, help me out. thanks
2answers
I have a 32inch prive remote dose not work how can i get one
i have a 32inch prive remote that dose not work how can i get one or find a code or the replacement remote
2answers
My tv is JVC i forgot the code now i cant watch tv please help
From what i know there is no code for TV. If you mean V-Chip code, just replace the asterik signs with zeroes. Or enter 0000 or try 1111. Good luck :)
Looking for a manual for a soyo prive 32 model
[email protected]
i have a soyo 32' flat screen tv. i bought it a couple of years ago, but i have a manual that i can photo copy and send you
Power Button
Try pressing the ch+ or input button. Some inexpensive models have that luxury.
1helpful
2answers
8helpful
5answers
Prive lcd tv remote codes
no manufacture has that brand in the code list. but soyo did come out with their own remote that will work satellite/cable boxes. Go on their website. www.soyo.com
3answers
Find a tv code for my prive soyo.
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
2answers
Remote codes for a cable STB Explorer 3200 cable box and a Prive 26" TV
Call the provider of the box and they will walk you through it on the phone...usually.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
