JVC GR-AXM17U Camcorder Logo
Posted on Oct 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size tapes does the JVC Compact Camcorder Model # GR-AXM17U take?
Cory Malantonio
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Oct 03, 2010
Cory Malantonio
Expert
Level 2:
New Friend:
Answers
45
Questions
0
Helped
10976
Points
134
Using movie maker to upload from JVC GR-axm17u (older camcorder) Got it hooked up to pinnacle usb device. I see the movie clip on my PC but the quality is terrible. Looks great on my camera as it is...
The USB device may be converting the footage to a very compressed codec.
Computer playback is not intended for interlaced footage as the camera produces so this may impact on the viewing.
Converting Compact VHS is best done with an Analogue to Digital Converter over a firewire connection rather than a USB device if you wish to edit in Movie Maker.
Al
I need owners manual for JVC camcorder Model # GR-AXM17U
http://resources.jvc.com/Resources/00/00/94/LYT1377-001B.pdf
1helpful
Camcorder eating tapes
Your problem is a plastic belt that drives take up and supply reel. Most likely, you will not be able to relace it by yourself.
How to hook up jvc gr-amx18u vhs-c analog camcorder
I use a Dazzle transfer box via it's UBS port. I think I payed $85 bucks for it. BestBuy.
1helpful
Jvc camcorder
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
Not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Repair
Try to check the drum final assy is good or not?
2answers
BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
