32 inch Sanyo Vizon LCD HDTV
Have a shadow line down the left side of my screen not quite top to bottom. Line is 1 inch wide in the center and tapers at both ends. The line is aprox 4 inches from the left edge and is near or at the smae place pillar box is placed.
The Diretv reciver is on that side it is the only equipment. I thought magnetism only affected CRT's.The Diretv reciver is on that side it is the only equipment. I thought magnetism only affected CRT's.
You can't post conmments that contain an email address.
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
The problem is in the LCD panel itself. I am an authorized tech for Sanyo, and in the Chattanooga TN
area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and
then ask for customer service. They will be more then happy to assist.
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
