SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
SOURCE: FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
SOURCE: Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
SOURCE: xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
