Dear All, I have a problem with my flash which is Kingstone 8GB while I format it Fat32 start formatting till 100% of operation then give me an error "The format can't copmlete" then I can't open or deal with it. I formatted it NTFS and the I can open but when past files sometimes I can & many times can't Thanks for your time& support.
SOURCE: kingstone hard drive 2GB
Right-click on My Computer and choose Manage
Click on Disk Management
Right-click on your Thumbdrive and select "Change drive letter and paths"
Give it another drive letter and see if it sorts itself =)
SOURCE: I can not able to format my Kingston 64gb pen drive
Hello there. you will most likely have to buy a disk utility like partition magic, or some such. if you go to softpedia .com there should be some good free/shareware programs there.
SOURCE: unable to format the drive r copy files to the drive
Pocket Fuzzies?
Get a bright light and look into the USB connector
of the Cruzer. It is possible that there is lint, paper bits, cookei
crumbs, etc in there and that is your problem. The outer 2 connections
of the USB is DATA and the inner two Power. B/C it is able to flash,you
are getting power... but the data lines may be dirty, covered, bent,
etc.
Clean it up and try again. Flat toothpick, small ty-wrap or
Proxident (dental/braces) brushes work well for this - DO NOT use
anything Metal!! It will scratch the connectors and vastly shorten
their life (they are GOLD plated)
Short of that, goto HP
site and get their USB format tool (get it here:
http://files.extremeoverclocking.com/file.php?f=197 ) and try
reformatting... if that doesn't work, it is hosed and only I can fix it
so let me know ;-)
SOURCE: Problem in 8GB "Redwan"
I'm very glade for this care of you. I take the programe in "8 GB" Kingstone and I foramat it by this prog. and find the analoge for size then the size become full ..............
if you have any new in usb send it on my mail
best wishes
Eng, Redwan
28/1/2009
SOURCE: card will not format in motorola razor.
You can purchase a USB media card reader for very cheap. Try formatting it that way. Otherwise you will need to try a different card. Once you have tried these solutions let me know if you still need assistance.
Thank you,
Lee
