How do you set the clock on a TEAC SRL100?
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
This worked perfectly. thanks alot.
how do you set the clock
Who designs these things without making clear how to set the clock? How do you set the clock display on the TEAC SR-L100 CD clock radio? The dial on the right is named "Tuning / Clock Adj" so that has a role.
The tone on the TEAC SRL100 is magnificent, rich, a great value. But the blinking 12:00 is driving me nuts, and pushing all the buttons and dials and turning them, sometimes simultaneously, seems to do nothing as far as even changing the clock time, much less setting it properly.
What's the secret?
Jeff in Fort Worth
I guess I am having the same problem with setting the clock on the TEAC SRL100 as the others. Any help?
Thanks! I got the time to set, now how about the alarm. Anyone know where i can find a pdf of the instructions for the TEAC SR-L100?
how did you get the clock set? I am having the same problem. Thank you for your help
