My house is very hot. The blower come on but air doesn't come out the vents on the house
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
1 of 2 issues are causing your problem maybe both.
1st. not enough air passing over the inside coils. could be fan speed or dirty filters.
2nd. the refrigerant charge is low
My fan won't blow inside with the cool at off.
SOURCE: My blower motor doesn't blow air out the air ducts why
Friend,
Happy to assist you!
Perhaps a bad blower.
But sounds like low freon!
If freon is low unit will not go on!!!!!!
Could just be low or could be a leak!
Words alone will not remedy the situation!
Dop not wait to fix it next year!
The cost will be more then Bad Infaltion!!!!!!!!!
You need to call service !!!!!!!!!!!!!
Thanks for your support. That fixed it and now my house is nice and cool. On behalf of my whole family we thank you and have a great day!
my air conditioner isn't blowing through the vents of the house. the outside motor is on but no air action in the home.
air is not blowing out the vents , motor and fan are running
My Carrier a/c is runing, the blower fan is running but air isn't blowing out the vents.
My house is very hot. The blower come on but air doesn't come out the vents on the house. I put in a new filter
