SOURCE: BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
SOURCE: how can I play youtube in my blackberry 8900?
Hi all,
This is because of the BlackBerry Browser as it doesnt support the Video Codecs (protocol).
If you would like to view video content from Youtube, you may have to download other Browser(s).
Another option is "Opera Mini". Which can be downloaded from this address:
http://mini.opera.com
on your blackberry browser: Press "goto" and then goto this address.
Select download and install the mini opera 4.2 application.
once up and running, you should be able to play video content on your blackberry.
(for the people who require to view the content on WIFI, they should go to the preferences of the opera mini browser and select the wifi checkbox).
Will appreciate if you can rate the offered support by me.
Best Regards,
Techno-geek.
SOURCE: Very low ring volume in blackberry bold 9000
I had the same problem. My ring was getting lower everyday. I've done my fair share of dropping the phone.
So, I read that other people were having the issue.
One genius, told us to take off the back plate, and just where the camera is, there is a greyish plastic plate riveted down with plastic knobs. You press on either side quite hard. If you can do this while the phone is ringing, you will hear the volume jump up and down. When it sounds just right, leave it alone, put back on the plate.
If it happens again, repeat.
You may need to buy the speaker plate after a while. It's only 10 bucks on cnn.cn
SOURCE: Blackberry 8900 Curve is blocked
This happens because the software might got corrupted, you need to reinstal
the software of your Handheld, Or walk into the service center.
Thank you for using Fixya.
