All machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test it to
make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
I'm trying to help my neighbor with christmas gift but she lost her manuel and neither one of us know how to thread the machine...
