Question about Electrical Supplies
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the layout of the switch. in the switch panel i have three wires coming in (black,white,ground) going out of the panel i have 4 wires (black,red,white,ground)i hooked up the switch with the hot wire and have two lines going out (one for light one for fan) tied the neutrals together and grounded the box. in the fan ceiling panel i have 4 wires coming in (red,black,white,ground) with 3 wires going out (black,white,ground) i proceeded to attach the red wire controlling the light to the wire in the fan controlling the light as well as the black wire going out to power additional items in the circuit, i attached the black coming in to the fans power line. tied all neutrals together and grounded the box. my one problem is and i know why the problem is happening is that when i turn on the dimmer for the light all other light and outlet that are on the circuit come on, when off nothing works. i need to know how to solve this problem. please help
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Posted on Oct 03, 2010
SOURCE:
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
S2-LFSQ my switch has worked fine for years. Now when the light is on it flashes on and off over and over. The fan switch works fine. Any ideas?
The only obvious idea I can think of is that someone swapped the light bulbs out for a different kind (replaced an incandescent with a non-dimmable compact fluorescent).
If it isn't directly related to the light bulb, then I would call Lutron's tech support number to help them diagnose. They're at 1-800-523-9466 and are available 24/7.
Feb 15, 2011 | AMS Lutron S2-LFSQ Skylark Dual...
L purchased a Lutron S2-LFSQ for our bathroom light and fan. l was informed by the store, this item was job specific so wouldn't have fan burnout. l now discovered stamped on the switches aluminum edging;...
Yeah, it matters.
The first thing is that the fan-speed in that control is only rated for 1.5-Amps. The issue with bathroom fans (I have to assume an exhaust fan) is not only how much current they pull during normal operation, but what happens if the fan rotor locks - that can pull some pretty hefty current slugs that the device is NOT rated for.
Also, generally speaking, putting fan-control on an exhaust fan doesn't work that well. If you slow down the speed at all, it significantly minimizes the amount of air-flow going through the room - which means you're using all of that energy for basically nothing.
My recommendation is to instead get Lutron's MA-L3T251- device. Here, you have the dimmer for the lights (same as the control you bought), and you have a timer switch that's rated for general purpose fan loads (up to 2.5A).
Nov 26, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
II have a switch and dimmer and the three wires from fan and light, no instructions how install it.
You will have power coming in through a black wire and white wire on the cable set that does not go out to your fan. The black will connect to your switch to power it. Then there will be two other terminals on your switch one for your fan and one for your light. The red and black that go out to your fan and light are connected to these two terminals. The whites get connected together. If you mix the red and black up and the switches are controlling the the wrong things, simply switch the black and red wires. (Note: If by three wires to your fan you meant black, white and bare copper this dual switch cannot be used, as bare copper is simply a ground wire and cannot be used as a constant electrical conductor.)
Jun 05, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Trying to hook up a Lutron fan control and dimmer
The old switch is just a single pole switch. The new one is for fan speed control. You need to use a regular single pole switch like you had. Or you can use a single pole switch on the Lutron you bought if you can figure out which wires to use. Do you have a meter?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 27, 2009 | AMS Lutron S2-LFSQ Skylark Dual...
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Electrical Supplies Logo
185 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
