Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
Posted on Oct 01, 2010
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always make sure that the filter at the bottom of the dishwasher is clean. I also make sure that the spinner is able to move freely. But, after all of that, I sometimes get very clean dishes; even more often, not. I see no rhyme or reason. I am presently looking at an entire load that has gone through two complete cycles, and am stuck with a bunch of filthy glasses.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
756
Points
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
  • donnawargo Nov 20, 2010
    I have the same problem on my 2 year old Bosch, I use Cascade liquid--like you I checked all of the possible causes--I also increased my hot water temp and run my sink to get water hot before running--all with no luck. I am handwashing after dishwashing:(
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 • Dishwashers
Leaves fine grit inside glasses, cups, etc. Dirtier dishes than before washing.
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The "fine grit" is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
1helpful
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
5helpful
2answers
Dishes and glasses being etched; looking dirty; embarrassing
First of all, if you're talking about actual glass as opposed to crystal, glass can etch easily. Why? Because like crystal, there are variations in its quality. Cheap glass will etch faster with the use of an electric dishwasher compared to higher quality glass.
Did you know that the main constituent in most automatic electric dishwasher detergents is sodium hydroxide (lye) and chlorine bleach (another caustic acid)
A Bosch dishwasher has very long wash cycles, further exposing your dishes to the possibility of etching damage. You should stop using the sani-rinse cycle if there is such an option and switch to a gel format detergent as opposed to a powder. Use a rinse agent such as Jet-Dry. This should solve your etching problem.
11helpful
2answers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 • Dishwashers
16helpful
6answers
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 • Dishwashers
Dishwasher Grit?
Hi julie
Chances are you are using to much detergent and the water is not hot enough. cut back on the detergent and run your hot water tap at the sink first and that should fix it.
brent
Sep 29, 2008 • Dishwashers
Crusty stuff on glasses after wash cycle
I never figured out what caused this problem. I cleaned it and took it all apart, could not find any debris lodged anywhere. However, I solved this problem! I now only use Cascade Complete dishwasher detergent. Has to be the "complete" version of Cascade. No more grit - nice clean dishes now and sparkling glasses.
Viking Dishwasher leaves a film on the dishes
Hi! I found a great product at www.dishwasherfilter.com that will take care of this problem for you and your wife. It mounts under the sink and works great!
Use promo code DF5150 when ordering for an additional discount!
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
