HI I HAVE HP LASERJET COLOUR 2840 ALL IN ONE PRINTER WHEN IAM PERFORMING THE TEST PRINT IT GIVES THE ERROR : FUSER ERROR RESTART AND TRY AGAIN
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
My printer is throwing a 50.2 fuser error. I have done all the troubleshooting I can including taking the fuser out and re-inserting it. The fuser sheet is ok but there is a lot of ink on it. looks like I need to replace the fuser and was interested in pricing a replacement.
SOURCE: FUSER ERROR
I just reviewed both of the above fuser issues (50.2 & 50.3). Both are highly likely (even if recently replaced) fuser damaged. I have included below a link to a free HP service manual for your machines. Start on page 309 using a volt/ohms meter to test the fuser. To address the "Guest" inquiry regarding the HVPS, there is a separate HVPS however please be aware that it is not part of the fusing circuit in this machine. If anything it would be the LVPS (Low Voltage Power Supply) however very remote. Odds are maybe 1 in 200 on your best day. I'd put 10 fusers in the machine before I bought 1 LVPS. This machine is known to eat fusers. The HVPS and LVPS at this time are just about bulletproof. PLEASE TRY TESTING THE FUSER AGAIN USING THE MANUAL PAGE 309 TO 311. If your really want the power supplies though, they are on the part number list at the end of the manual. I just looked it up and we have repaired 74 of machines to date with not one PS ever used. 59 of the 74 have been for fuser issues.
Here's the manual link:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you both. :)
There is a number - 50.1 - that appears with the FUSER ERROR. Do I need to replace the fuser? The printer is currently inoperable.
Jane
I am getting a 50.2 fuser error when trying to print. It says to turn it off/on which I have done but nothing works.
Can anyone tell me where the fuser is ?
Does it show a code number like 50.1 ?
Larry
