Jabra SP500 Wireless Headset Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pairing It won't finish pairing due to not having pin nimber. What can I do
Christophe Thompson
Level 3:
Genius:
  • Master 1,224 Answers
  • Posted on May 26, 2008
Christophe Thompson
Master
Level 3:
Genius:
Answers
1224
Questions
Helped
596179
Points
3052
Ok this is simple they dont put it in the books but i found out going to the techs.
when it gets to the pin type in 0000
1234 or 12345
i dont know why they dont put these in
2helpful
Nokia N95. What would be the pairing code from a Nokia N95 to a generic pair of Bluetooth headphones please?
My first thought was that the phones doesn't have Bluetooth, but it does.
https://www.gsmarena.com/nokia_n95-1716.php
The key to the code would depend on the make and model of the headphones. Likely to the '0000' or '1111' or similar.
The most common PIN is four zeroes in a row, 0000. Two others you may encounter on some devices are 1111 and 1234. Try entering those when you're prompted for a PIN, starting with 0000, and most of the time, the pairing finishes successfully. If issue persist, proceed with these steps.
Feb 1, 2021
Asking Pin for Bluetooth Earbuds - Microsoft Community
Microsoft Community https://answers.microsoft.com > windows > forum > all
About featured
What is the Passcode or Password When Pairing ...
Sony https://www.sony.com > electronics > support > articles
May 25, 2022 - Use the code 0000 when pairing with another Bluetooth® device. The passcode may appear as Pass key, PIN code, PIN number, or Password depending ...
How to pair Bluetooth devices: a generic guide
Mobile Fun https://www.mobilefun.co.uk > Home > 2015 > April
Apr 20, 2015 - Speakers, headsets, car kits, gamepads: Hold down their multi-function button until the peripheral beeps or flashes. If the first response you ...
tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 • Cell Phones
Pairing my samsung galaxy grand prime phone with my 2014 honda cr-v vehicle
the password or pin is likely the password or pin to open the phone.
How to connect to phone
Pairing the Headset
*You are required to pair the headset with your mobile phone or other device before using it.
1. Ensure the headset is off, then press down the P2 button until the pairing mode (both Blue & Red-LED's are flashing
alternately), then release. This will take about 6 seconds.
2. Initiate pairing process of your mobile phone. Refer to the manual of the mobile phone for the direction. You will see a new
item "BT headset" added in your Bluetooth device list after the searching process.
3. You will be asked to enter a pin code to complete the pairing. Enter 1234 and confirm. (Note: the 1234 is a default pin code
pre-stored in the Headset) The red indication will turn off and the blue indicator will flash slowly after the paring is completed
successfully.
4. Once the pairing is complete, the Red LED will turn off and the Blue LED will begin blinking, (indicating standby mode). If it is
not finished paring within 2 minutes, the headset will go into standby mode, and pairing is unavailable. You will need to restart
and repeat steps 1-3.
MANUAL HERE:
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
6helpful
How do you turn this device on and pair it with your phone?
to turn this device into pairing mode hold the power button down for 8 to 10 seconds,then a light should stay on.once you have put the bluetooth device into pairing mode you phone will find it and ask for a pin\pairing code.most bluetooth manufactures use a 4 digit pin\pairing code they are as follows ,0000,1234,9999,or 1111 and try them in that order one should work for you .Hope this helps
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
1helpful
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
12helpful
2answers
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
17helpful
CABLE & WIRELESS CWBTH160
To initiate pairing, put the devices within 0.5m of eachother
Make sure phone / pc bluetooth is on and discoverable
Make surea headset is fully charged
  1. Ensure headset is switched OFF
  2. Press and hold the talk button (big central button on front of headset) until the indicator flashes red & green alternately, then release. Headset now ready for pairing.
    Note: Headset pairing mode will time out after 5 mins.
  3. To allow phone / pc to "find" the headset, consult your phone / pc bluetooth operating guide on pairing devices.
  4. Headset should be listed on phone / pc after search has finished - highlight and select the headset.
  5. A pin or password screen will appear, you must enter 0000 and confirm.
  6. When pairing is successful, headset indicator will change to green and flash continuously every 3 seconds.
Pairing is then complete.
Note: Multi-pairing.
It is possible to pair up to two phones with the headset - the most recently paired phone becomes the "primary "phone... only one phone can be connected at a time --> this function only works in Hands-Free profile. If both phones are in range, then the headset will connect to the "primary" phone first.
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
