Rangemaster 110 (Gas) Kitchen Range Logo
Posted on Oct 01, 2010
I have a rangemaster leisure 110 my timer was flashing but was able to reset it, now the clock is on auto showing 0.00 and using the two buttons for 6 seconds then pressing plus or minus nothing happens
j_burrell55
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 04, 2011
j_burrell55
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
8328
Points
8
How can I get to the clock, I want to disable the auto timer, I cannot seem to find how to get to the wires, the hot plate (warmer) needs to come out first I think but cant see how to get it out ..URGENT
Many Thanks
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Timer not working - flashing auto permanently so cannot light either of the ovens. Have tried reset but has not worked
Try the 6 push buttons under the clock.
press in the first two buttons from the left simultaneously and then the - and + to adjust the clock. Thats how it works on my Classic 90 but not certain about the 110
1helpful
2answers
The ovens in the rangemaster will not work as the timer is not working. The timer will not flash and when it does decide to flash it goes right back to non flashing zero. Can i use the cooker without...
Try putting your grill on low for 30 minutes to one hour the clock should start to flash then leave to flash for five minutes after which press reset. It worked for me on my rangemaster 110 (gas)
Have leisure rangemaster 110 5487 ng cream. Have totally lost display for clock, timer etc. How do I replace this?
Phone Gas On Spares with model number 5487 followed by the following 6 numbers after 5487 and they will quote you for a replacement Programmer
1helpful
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
8helpful
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
2helpful
2answers
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
11helpful
3answers
Rangemaster 110 gas model
I have downloaded the users guide from rangemaster.co.uk which has details of how to change parts & a wiring diagram, Hope this helps. Here is a section..............
5. To Remove Clock
Disconnect from electricity supply.
Remove the Control Panel (See 2). Pull off the timer
control button(s).
Remove the timer/mounting bracket assembly from the
control panel by removing the fi xing screws.
Remove the timer from its mounting bracket by
depressing the plastic lugs on the timer case, at the
same time pulling the unit forward.
Reassemble in reverse order. When replacing leads
refer to the wiring diagram. Check operation of timer.
BEFORE SERVICING ANY GAS CARRYING
COMPONENTS TURN OFF GAS SUPPLY.
35helpful
5answers
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
