Just do the following
Press
Windows key button and simultaneously press D button
Now Press and hold Control button and now keep scrolling the mouse scroll wheel (dont move the mouse just scroll the scroll wheel) up and down side, you can see the sceen getting smaller or bigger, Leave the control key as per your preference of screen size.
ENjoy.
use this if using windows vista/windows 7
Set the zoom level in Magnifier. This can display objects on the screen up to sixteen times larger than actual size. Follow these steps to choose the magnification level that you want.
In the Scale Factor list, select a level. The zoom level in the Magnifier window will change right away. Adjust the level until it's right for you.
use this if in windows xp
1 Click the "Start" button in Windows.
or try the accessibility mode
1) press start goto control panel be sure use are in classic view
2) select accessibilty options and select display tab and uncheck the enlarged icons option and apply and click on ok. this will reset all programs to a smaller view.
ROB
