Sounds like problematic issue.. kind big and tricky.. I think u should refer to some online guides..google or there v helpful n u don't need to refer to anythng else.. like reliable-store.com is gud fr this.. do tell me how it goes.. so easy!
hi daddy hector the motorola driod comes with a 16 gb card if you are using a 2gb the phone's memory is slowing the phone down. You need to put the 16gb card back into the phone. Now if you have the droid 2 the 3g is faster because it is using the a faster processor. Where you got the phone is also important. It sounds like you got the phone from an authorize dealer. Teh corp stores are selling the driod 2 global. So you need to speak to the corporate national customer service and see if your phone is indeed a brand new phone. Hope this help
May be your phone is muted.Go to settings then sounds and profiles in there you can find profile name normal.Select and edit it.When you edit that profile select the volume level to 7 for all.Then your sond problrm will rectify
since its an 8megapixel camera on a phone its takes a while for it to process the foto. you shouldnt move the phone while it processing otherwise u will get either a blurry picture or somethign else. if u want the phone to take faster photos try decrease the resolution for the photos.
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Sound issues are existent withinin vista onwards as is decreased from normal as with xp and previous. To fix problem of this depends on installing an appropriate os system...
■ Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
