5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
Posted on Apr 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I adjust the sensitivity of my alarm? I can slam the tailgate and it will not go off. Also, I can activate my remote start and it will start and run, BUT, oftentimes when I hit the open door button, the engine will shut off. When I get in, the system will be on and ready to start again (I have a Diesel set for 30 seconds) and it will start again after a few more seconds. Please don't tell me to go back to my Dealer! I probably went back 10-12 times following the initial installation and it became apparent they knew no more about the system than I did!! Ernie South Carolina
Louis
Level 2:
New Friend:
  • Expert 33 Answers
  • Posted on Apr 26, 2017
Louis
Expert
Level 2:
New Friend:
Answers
33
Questions
0
Helped
7014
Points
136
To adjust the alarm sensitivity there is a sensor usually on the steering column with a plastic screw that can be turn to adjust the sensitivity. To change the setting you will probably need the manual for the alarm and there is a wire with a small button on that to program settings for alarm sound or remote start start and stop time.
1 Related Answer
Anonymous
  • 12 Answers
  • Posted on Jan 15, 2009
SOURCE: remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
I have a 1999 3.5 Camaro. Whenever I lock the doors using the transmitter or the power locks to set the OEM alarm system, about 2 seconds after shutting the doors, the alarm activates. Other than the alarm...
Hi there sir . This is the only way to solve your problem. Goodluck and let me know.
The shock sensor is what triggers the alarm when it
detects a blow to your vehicle. It is located over the
right rear wheelhouse near the spare tire in the hatch
area. There are two levels of alarms via the shock
sensor. Two horn blasts and parking lamp flashes for
non
-threatening blows to the vehicle and a full
two
-minute alarm for harder blows to the vehicle. Its
sensitivity can be adjusted if more or less sensitivity is
desired. If sensitivity is increased too much, it may give
false alarms caused by gusts of wind or other natural
events that may shake the vehicle.
To adjust, remove the label covering the adjustment
**** and adjust as desired. Turn the **** clockwise to
increase sensitivity and counterclockwise to decrease
sensitivity. The shock sensor is ignored by the alarm
system when the ignition is on, when the hatch is open,
when the alarm is disarmed, when customized to be
ignored and for five seconds after the horn sounds an
alarm or chirp. The shock sensor is ignored after
triggering three full alarms until the system is rearmed.
Regards jo
tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 • Televison & Video
2answers
Why my alarm want stop going off?
Week or dead battery on your remote. Change the remote battery, got nothing to loose except a couple of bucks
2helpful
2answers
Lock car with remote, walk away, alarm goes off. put car in garage locked, 4 hours later alarm starts
Sounds like the sensitivity is set to high. The dealership should be able to adjust that for free. Hope this helps
How do i turn up the sensitivity on my alarm?
you will need to find the IMPACT sensor and use the dial on it to adjust the sensitivity.
2answers
Can the sensitivity for the alarm system be adjusted
no, there are no adjustments.. if the alarm has an issue then a code should be stored. You will need to retreive it to begin with.
1helpful
2answers
Auto tailgate warning light is on dash board but tailgate closed.
I have a similar problem, my tailgate stopped working with the outside handle and the remote but can be opened manually from the inside. I don't have an alarm so there is no problem with that but did you get a solution for the tailgate problem that I could try?
2answers
Does my 2007 f 150 have a shock sensor that will trigger the factory alarm if a window is broken? If so how can I adjust it?
yes... on the unit itself. there is an adjustment screw you'll need to turn in one way or the other for sensitivity
8helpful
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
We live in Phoenix Az. We have a 2005 Honda Accord 4dr LX 4 cyl, automatic, AC with factory alarm. The alarm goes off "at will" when parked at home, in parking lots or wherever. It just went off when a...
do you have a remote for alarm? if yes adjust sensitivity with remote push to arm and hold. if you have a sensor under the hood adjust screw on top of sensor.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
