Cars & Trucks Logo
Posted on Oct 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1998 ford escort zx2 four cylinder an i just put a stater on it an while i was putting it on i accidentally broke a red and yellow wire on the harness an i dont know were it suppose to go it split out of the harness bellow starter wires
Anonymous
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Oct 01, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
11707
Points
146
All wires in a cars harness are color coded so now carefully cut the tape back until you find the leads and then repair them. you will need to use wire connectors don't just twist them together. by the way those are the solenoid wires.
2003 Ford Escort ZX2 stereo wiring diagram please?
2003 Ford Escort ZX2 Audio Wiring Chart
MODIFIEDLIFE https://www.modifiedlife.com > 2003-ford-escort-zx2-...
Our 2003 Ford Escort ZX2 radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Ford Escort ZX2 Radio Wiring Diagram ...
2000 Ford Escort ZX2 Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
2000 Ford Escort ZX2 Stereo Wiring ; Antenna Trigger, n/a ; Antenna, Right Rear ; Front Speakers, 5 1/4" Doors ; Left Front (+), Purple ; Left Front (-), Blue/Orange.
Ford Escort Stereo Wiring Diagram
Pro Street Online https://my.prostreetonline.com > 2016/03/10 > ford-es...
Mar 10, 2016 - The Ford Escort was available through three generations, and today I'll be showing you our Escort stereo wiring schematic from 1980-2003.
I have a 1998 Ford Escort ZX2. One side of the back seat goes down, but the other side won't. What's going on? There's no button, there's no lever?
Question edited for correct spelling of model 'Z2 X' to 'ZX2'.
Question moved to model category.
It looks like a split rear seat, 1/3 -- 2/3. The catches would be in the boot, upper left and right. Regs dictate it can't be done sitting in the seat.
http://gtcarlot.com/data/Ford/Escort/1998/4022820/Trunk-66176204.html
https://www.google.com/search?q=1998+ford+escort+zx2+lower+back+seat
Manuals
https://www.google.com/search?q=1998+ford+escort+zx2+owner+manual
2answers
How do I remove key cylinder on Ignition switch? 1998 ford escort zx2 2.0 four cylinder
You must remove the steering column plastic covers, they unscrew from below.
What would cause dimming dash lights when putting on headlights in my escort zx2
usually a bad ground wire, or something in the charging system
How to install timing belt on 1998 ford escort ZX2 2.0
put #1 piston at TOP DEAD CENTER and align your cam marks . then time igntition timing with a timing light
I have a 1998 Frord escort Zx2. when you
Make sure it is full of brake fluid first. If it is, check for leaks around the clutch master and slave cylinder. The master cylinder is mounted on the firewall below the brake master cylinder and towards the driver side. Follow the line to find the slave cylinder on front of the transmission. If you find no leaks, either the master and/or slave cylinder is bad or the clutch fingers are broken.
Ford Escort ZX2 1999, need to replace accelerator
Look at the cable routing. Figure out how to replace it. Consult shop manual or Service manual.
2002 ford escort zx2 camshaft sensor fit a 99 zx2?
Yes, All the years of the ZX2 utilize the same engine. 1998-2003 are all the same except for ECU programing and the MAF wiring. You should not have a problem.
21helpful
3answers
1998 Ford Escort ZX2 Water Pump Housing removal
I am sure the leak is the water pump based on years of Escort work, The ZX2 is equipped with a 2.0L DOHC V-Tech engine. The water pump is on the front (rt side of car) of the engine block, visible with the hood up. NAPA autoparts replacement instructions are to loosen the belt drive pulley from the pump BEFORE removing the serpentine belt. Once the four bolts are loose, take the belt off (good time to replace?) remove bolts and old water pump (four more bolts)- it will be tight, but it comes out- clean gasket area and install new gasket and pump in reverse order. That includes putting the pulley on and hand tightening the bolts, put on the belt, finish tightening the bolts to the pulley.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
