It is really hard to determine if they are strong or not by using meters or testing equipment.It's possible but not likely that your charger isn't bringing them up to the right level.Perhaps your tech can look at that too.I would find some way to install a known good battery set for comparison if at least temporarily.It's also a possibility that the drive motor have been working extra hard lately in your travel. Have the tech check those if he/she can. Hope this helps
The problem of your legend XL can view from two different ways and also be view at same time from point.
1). From the wire connections and
2). From the ulterlator (i.e motor battery changer).
What you are to do to fix up this problem is to carefuly trace the wire of the power connector if it providing power on to the battery ,if dose not then it means that there is a power faile from the power which has been the couse of the power faile of the battery.
Then the wireing programm will need to be rerun so a to solve the battery problem.
Thank you and thank for using fixya.
Batteries go dead after 20 mins. They are two
months old and replaced original batteries
that acted exactly the same. When batteries
are discharged it takes only one hour to be
fully charged. Batteries tested under load
and found to be good. Battery charger tested
good having output of 27.9vdc. When new scooter
travelled approx four times the distance it
now does
