SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
SOURCE: Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
SOURCE: Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
